First post here so forgive my ignorance! I did however do a search to see what had been posted up before and culdnt find much, so here goes...
Why convert? I know alternators are less speeed sensitive, ie produce a charge at almost any revs, but unless idling very slowly the red genny light doesnt come on.
As i understand it, the gen light actually means that the battery is discharging, so no light (unless its bust of course!!) means the battery should be getting a charge - yes?
I ask becauise the battery wont hold its charge - after a long drive its fine for a few hours, but by next morning (say) - almost flat again.
I think this is a battery problem not a charging problem, but not sure. If my above thinking is wrong, maybe the genny doesnt produce enough charge to recharge a battery, unless revving really high? (well - not pootling round town, anyway)
Obviously a new battery is the first thing to try, but if thats nbot the problem, thenmaybe the genny is on the way out. But am i better off fixing/replacing genny or doing a conversion to alternator - as I said - whats the plus side?
By the way - in seraching the forum i found a few queries about other reasons for the genny light not going out. I found that when i misconnected my side lights with ground to live and live to ground, the fuse blew (perictably enoiugh) and the red gennty light then came on. IT glowed stronger if you used other services, eg lights etec. Once thye fuse was replaced and sidelight rewired properly, the red light went out again. Might help someone else someday?
