Electrical hookup - Female socket in van
iknowdavehouse
Active member
Mar 18, 2017
42
I've just been checking out the electrical hookup put in my bus by a previous owner. I've barely used the hookup at campsites previously but this end should be male, not female right? Do I need to put in a new socket or is there a convertor plug available? I've looked around but I can't find anything online...
Ive wired mine like this as mines under the van so I wanted a flappy lid like yours in the pic.
Just cut the end off your hookup cable and wire in a new plug? There only £6 in screwfix and £3 on ebay.
Or if you don't want to damage your hookup cable, buy both ends and make a short adapter cable like this
If your not electrically minded, its only 3 wires
Personally i'd change the socket on your van as it's potentially dangerous if you didn't plug into the van first. Regardless of that fact, as an electrician myself it's just plain dangerous anyway.
If you search "16a appliance inlet" you'll get what you need, but you may have to search a little harder to get one with a dust cover over it ... then it's just a case of swapping it over like for like and you're good to go.
Thanks for the info, I was considering making a male to male lead up but I was concerned about safety as matty has mentioned. I'll see what I can get hold of...I think I've seen some separate dust caps that might do the trick...
Yeah get that changed buddy, really dangerous to have a live plug going into that.
