My crankshaft seal had been leaking oil so removed it and the flywheel o ring.
In this configuration I measured 0.24mm Endfloat using a DTI clamped to the case measuring close to the centre of the flywheel.
I fitted new shims to achieve Endfloat of 0.09 - 0.10 mm within Haynes tolerances of 0.07-0.13mm.
Installed new genuine crankshaft seal and flywheel o ring torqued the new gland nut to 253ft/lbs and now the flywheel feels tight. Pulling fwd & aft doesn't seem to show any movement although I haven't measured this.
I know the o ring will take up the slack I'm just wondering if this situation sounds normal having never done the job before.
I torqued up to 253lb/ft each time I measured the Endfloat
J
J
