End float
vinvan
Aug 24, 2013
762
2
North West
hi
Need some more info, just been checking the end float on my engine i don't have any movement whatsoever! do i need to remove some shims to give some movement ?????
Have you just built the engine or is it a running engine in your bus?
If its a running engine then how many miles has it done?
How are you measuring the end float? You need a dial gauge because the measurement is very small.
hi
thanks for the reply, don't know how many miles the engine has done it was out of the bus when i bought it, and its not the original engine
will check again with a dial gauge and post the results
