MarkC68
Hi guys,
I've got a couple of questions to ask...(dont normally post as searching thoroughly helps me out).
First off, do the pushrod tubes have to be fitted in a certain manner - on ours the seams are fitted in what looks like random. Am I correct in saying all of the tubes should have seams that point to the "12 oclock" orientation when looking from above onto them. None appear to have any sense of fitting order to them.
Secondly, how do I determine the engine type (it a twinport) but the engine number starts as AB..... (read from the front near the alternator) whereas I looked under the LH cylinder bank last night and below the pushrod tubes it has "AS41" cast on the block along with what looks to read 113-xxx-xxx...I understand the 113 (if read correctly) but which is the right enginecode?
Many thanks,
Mark
Many thanks,
Mark
