Final Drive flange
subheatadey
Sep 15, 2013
1,160
28
Batley, it's God awful!
Hi guys, wonder if anyone can help regarding gearboxes in particularly the final drive flange or maybe it is something further in? I have taken the gearbox out 'cos there was a bit of a knocking noise and on closer inspection there is a 'bit' of movement on the final drive flange in and out is this normal or should there be no movement if this is the case is there anything i can do about it, can I shim it or replace bits or is it something more such as the Diff being foooked - God I hope not - I'm skint :D
That's an early box. You might just need new bearings but when I last tried to get hold of some 3 years ago it was a mission. Perhaps try Bears gearboxes, they know their stuff but may only offer a re-build service rather than spares.
If it's the bearings you could try
http://simplybearings.co.uk/shop/index.html" onclick="window.open(this.href);return false;
Cheers Guys, seems to be the CV joints so I have repacked them with grease so they will have to do for now until I have the funds to replace - after 40 years service i can't complain really.
On the subject of gearboxes which i know little about is it possible to replace with a later style gearbox? Would this be a advantage and if so so type of gearbox would I need to look out for?
Hi Ade, the answer is yes, but only because you now has a few more ponies available to flog :shock: So you can now get a slightly taller ratio on your box, and there are quite a few possibilities, a 1303, or one from a two litre or talk to someone at Bears about your final drive or just run slightly bigger tyres. A five speed from an old Porsche was getting a decent review from Tofufi not so long back. So is you nearly back on the road bud ?
Ozziedog,,,,,,,,,,,, Run him in with the lower ratios anyhow, less stress less labour X2 :mrgreen:
