I took all the wooden furniture and bench seat out of my 71 Danbury to have welding done and now I'm in the process of putting it back along with new seat belts in the rear of my van.
With regard to fixing the furniture, what's the best way to fix it in as it originally was just held with a couple of screws. Also should I bolt down the ply floor to the metal?
I also have the the original seat belt mounting points and have had extra ones welded into the wheel arches. For the 3 point belts, when fixing the inertia reels I have bolts and nuts supplied but as far as I can tell there is no way to insert the bolt in the upper fixing? Do you just screw the bolt into the factory fitted point-would this be secure? The other points I would be able to get under the van to bolt the nuts in.
Final question, anyone know where to get the brackets to stop seat cushions moving off the seats at the rear?
