Supertramp
Can you flash your main beam without your headlights on?
*Sam* said:
Max Power said:I can't in a Cali bus,just pull the headlight switch,not too hard is it ?![]()
terrier man said:I flash all the time :shock: & mines a U.S Bus, think it depends on how yours been converted over here & what relay been fitted.
Nugsy said:I'm intrigued by this. Finally fitted my new indicator switch from EIS everything working fine or so I thought. Then tried to flash the headlights and nothing. When the lights are on dipped it swaps to main but no flash only if switched off? Going in search of threads now as I presumed it just needed a new relay, but need to read up now and make sure I get the right thing
Supertramp said:Nugsy said:I'm intrigued by this. Finally fitted my new indicator switch from EIS everything working fine or so I thought. Then tried to flash the headlights and nothing. When the lights are on dipped it swaps to main but no flash only if switched off? Going in search of threads now as I presumed it just needed a new relay, but need to read up now and make sure I get the right thing
My US bus will switch from dipped to main but then I have to switch it again to turn it off, no flash. Also I have to have my headlights on.
