vinvan
Pre wired relay and fuse board to fit above the battery that would have ign feed ,starter,fuel pump and split charge"
The feed from ign switch works via a relay so 2 benefits, there is no load on switch as well as no volts drop to coil, which can be the cause of poor hot starts.
This one also has the relay in place for a split charge as well as a feed for an electric fuel pump.
Comes with full fitting instructions
I bought mine but ended up not using it so I'm selling it on. I want £50 + post
Vinvan
Vinvan
