Front beam adjusters
danban
Apr 5, 2015
174
Hi guys do any of you know the thread size for the beam adjuster bolts?
I'm going to have to make a tool to help turn my beams as it's stuck!
Cheers Dan
Dan,
They are M14 fine (x1.5 I think).
The set screws are often hardened so may be brittle. I have slipped a piece of tube over mine before & have also used a socket over the nut & then heaved on an extension bar plugged into the socket.
Originally though, when I first got it, I had to remove the springs & inserted a rod/pole & whacked that back & forth many times to fully release the hold that the original dimples had.
As, I think, Clem said on your other post.
When this is all done, do not over tighten the lock nuts on the adjusters. The hardened screws can fatigue if they are over stressed - causing them to break. Your front end will then drop suddenly. Ask me how I know!
Phil.
Hi i have had to use high tensile bolts and make a tool up.
We heated the tube with hot air and with lots of pulling it slowly moved.
If anyone needs any bolts I have some!!!
