mcvw
Been to see my bus at the restorers (Kultklassix, Chiddingfold) this evening and since Bazza started cutting things back/out it looks like a complete front panel is required.
- The top lip of the panel where the bottom of the front screen/rubber sits has totally gone in places - and the seam has blown.
- It's unknown what condition the inner panel is like - but if the seams are blown, this could mean the inner panel may also need replacing.
- The grill hasn't been removed yet, so it's unknown what lies beneath this.
- The lower arc'd sections of the headlight bowl need cutting out and replacing.
- The bottom half of the panel needs the lower outer section and most of the inner panel (beneath indicators etc).
I know it's possible to get the repair sections/new panels for all the above areas, but the front would end up a bit like a patchwork quilt. Not to mention how much it would cost in terms of time (£'s per hour) to cut all the bits out and replace.
So... given the amount of repairs that are required, would it be more effective in terms of cost (and strength/shape?) to get a complete front panel? If so, who makes the best one? Are the new front panels faithful to the original panels shape/contours?
I assume all new front panels are "late" and require the indicators/badge sorting too.
Thank you,
Mike
Thank you,
Mike
