Front suspension swap
Marshy
Aug 31, 2015
360
Hi all, but of advice pls, bought some kyb shocks, went to change them and the bolts have a sleeve stuck to them, these seem to be stuck in place, am I supposed to get this off? May have to use heat if so, any pointers would be much appreciated.
Ta in advance
Guessing without seeing it that it's the bush from the actual shock, your replacement ones have one in the robbers hole?.
I put Billstein ones on all round but only remember the actual bolts had a smooth portion nothing else like that.
Thanks brad, I believe it probably is the original bush but wasn't sure, I'll get the things removed if I can and change the bolts
Sounds like original bushes. We had the original bushes on still as well. I think we ended up cutting down them a bit to pry them open and they then popped off.
