Just in the process of fitting dropped spindles and just putting hub back on. The old bearing and hub seal still intact. As I tried to push it back on the new spindle it got stuck and as I pulled the hub off the bearings were left sitting on the spindle. I got them off and pushed them back into the hub but there now appears to be a metal ring which came from somewhere. I think it might be from the hub seal underneath? Is there anyway to get it back in? When I push the bearing there does seem to be quite a bit of movement going in and out of the hub, is this normal? :
