Hi folks
I've read all the threads on fuel gauge problems but just need to be clear on a few things before cutting a big hole in my Van :roll:
My fuel gauge has decided to stop working, it never worked brilliantly to start with, jumping about a little.
I've recently run the tank almost dry, and after filling it doesn't seem to register any fuel!
Could the float be stuck? should i rack up a few miles hoping it will free up?
I checked the gauge as suggested on other threads by earthing it out on the back of the dash, and the needle jumps to full.
Also when the ignition is off the needle is far left as can be, but when the ignition is switched on the needle moves about 5mm to the right (to the empty position on the scale? (does this mean the gauge is ok? are there any other checks?)
Is there a way of checking the sender before i go hacking my poor van to bits?
I have a multimeter handy, but not sure how to test the sender, i was hoping there would be a simple check that involves checking the wire from the back of the gauge to the sender unit?
Please help before the van gets the dreaded sender removal hole hacked out out of it.
Many thanks.
Mike
Many thanks.
Mike
