meowdmucker
Fitting a 2110 engine into a 71 bay which has twin webber 44's with 8mm fuel connections. Also have a cb rotary fuel pump connected under the tank with 8mm connections also. The included fuel filter has the 8mm ends too.
Do I bin the cb filter and replace it with a stepped cheap plastic one to step up the fuel tank smaller diameter hose to 8mm hose?
Then what do people do to get the 8mm hose from the pump through the tinware as the metal pipe on my 1600 engine looks about 5mm internal diam.
Do you find a wider diameter fuel pipe ( if so what type ? 8mm brake pipe?)or just put the 8mm hose through a bigger hole with a bigger grommet to stop in chaffing.
Will the reduced diameter hose feed from the tank to the filter effect the running of the carbs? The pump is rated at 3.5 psi.
Hope someone can help. Thanks
