rustydiver
Gota smell of fuel, had a look in the engine bay no leaks coming from fuel lines, been replaiced in the last 6mths, but have found fuel dripping from the Inlet manifold rubber boot, looks cracked and perrished, wet to touch and smells of fuel.
The van is a 1.6 tp engine, crossover model.
Should it leak from here?
Needs to be replaiced, do i need to take the engine out to peplace?
Got a spare set in the garage, for some reason! would it be better to replaice with urethane type ones?
If its engine out, can i have an idiots guide for remove on a crosser van please, Cos im an idiot.
Cheers Rustyd.
Cheers Rustyd.
