Foz
A month or so ago, I had a problem with my indicators not flashing, was advised it would be the relay, so I replaced it. Removing the relay was a tricky affair having to move the whole fuse box out to get to the relay at the back. .
Put everything back as it should, indicators work fine again now, only for some reason now my headlights are stuck on main beam when in the second position on the headlight switch. Sidelights work fine. Headlight switch is new, and was wired in by an auto electrician
There is no clicking when I flash the main beam, so maybe the relay is stuck? Or a silly earthing problem?
Just looking for any advice or pointers as to where to look, which wires/fuse circuit or relay I should be looking at when I once again remove the fuse board to find the fault.
Any advice appreciated.
My bus is a 70 Westy btw.
own a Bay?........Feel the love!
