Got some resto left overs hanging round the garage. All prices are plus postage - Can post everything apart from the beam - or pickup from Weymouth or Yeovil
Thanks, Mike
07961904707
Porsche 356 Chrome Wheels -
link to to other ad here with more pics, but thought i would combine -
http://forum.earlybay.com/viewtopic.php?p=600075#p600075
£120 - can post for £15
68-70 Bay Beam - Bit dirty, but rust free - came of my 68 Swedish bay - onyl changed it as did a king and link pink conversion. Good original needle bearings too. Is LHD but steering damper bracket could easily by moved to the other side.
£130 - can courier for £20
Front Drums and splindles off the same 68 Bay - may fit a late split ? With very good backing plates and possibly new drums, cylinders and shoes (front brakes were refurbed before i bought the van) (wheel bolts not included)
Can split into bits seperately if possible
Drums - £75
Backing Plates £50
Spindles - £35
Inards - £15
or £150 for the lot
pair of spring plates off the same 68 bay
£15
clutch from an early bay practically brand new. has done maybe 40 miles max. i fitted it, but then i had a issue with my release bearing coming loose because of a bad clip and damaging my clutch fork. I upgraded to a later clutch when i renewed the clutch arm.
it is the whole kit - clutch, friction plate and a new release bearing (not the one that came loose!)
no pics at the mo, but like this -
£45
https://www.vwheritage.com/111198141x-clutch-kit-200mm-w-pad-sachs
85mm Mahle 1600 Barrels and Pistons - Practically brand New - ran for approx 50 miles, before change of plans.
£80
Thanks, Mike
07961904707
Drums - £75
Backing Plates £50
Spindles - £35
Inards - £15
or £150 for the lot
£15
£45
£80
