Gaz shock coilovers
rupert the bay
Dec 9, 2007
253
1
durham
OK - was gonna fit these to the back of my bus...but I spent too much money of crap recently, so need to move them on ;-/ hahaha
Gaz shocks coilovers.....totally adjustable damping....and variable hieght
they currently have 120lbs springs....which are perfect for the rear end of a HARD launching bug...or the rear of a bus....you MAY need to relocate the top shock mount ?? depending on your setup, i havent tried on mine
fit some softer springs and these will also work AWESOME on the front end of a bus
£150 plus £10 postage
Thanks, I'll check the height I require for the fronts over the weekend, think it's about 12", do you think they may drop slightly when fitted?
the actual piston will compress down to below 10"....but with the current spring length...wound all the way down the coil the distance would be 11" (thats with no weight on it, obviously)
