gear selection problem!
Sorcerer
Feb 16, 2014
6
Hi, I wonder if anyone can save me some exploration time and advise me on how to fix my early bay gear selection difficulties?
I have a 71 bay with a Scat bus shifter. I'm having difficulty selecting 1st gear and coming down from 3rd to second. It doesn't go into 1st easily and when trying to find second it crunches like its going into reverse. I think this is quite common. I've seen some forums say it's the shift plate that needs moving but I'd like to know if anyone has had the same problem and how it was cured?
Ta
Sorcerer
Go to page 2 in the general section and 3/4 of the way down the page click on Can't find it
This is a good place to start. I know. :lol:
J & P
:D :D :D
Here is the linky
http://forum.earlybay.com/viewtopic.php?f=1&t=60086" onclick="window.open(this.href);return false; :D
Also any parts you require can be sourced here
http://www.coolairvw.co.uk/Category/0/Shop_by_Vehicle~Baywindow_Products~Baywindow_Levers_and_Pedal_Products~Gear_Shifter_and_Linkage~Gear_Shifter_Linkage.html" onclick="window.open(this.href);return false;
I fitted a urethane gearshift coupling to mine to remove most of the slop in the shift
When I bought my bus two years I was getting the same thing plus I kept slipping into reverse when I was trying to go into 2nd. I changed the gear stick to the scat which stop me going into reverse but second still crunches....I've sorted out a re con gearbox.
