StuF said:Gene Berg locking shifter for me - got it direct from the factory in the states.
Fitted it myself and made the world of difference - not cheap but honestly my best aftermarket mod
strutt said:i believe the general consensus is a Gene Berg or CSP.
I have a CSP one and its cracking! although im sure this will be echoed, replace all gear linkage bushes whilst your at it
BARKING MARK said:StuF said:Gene Berg locking shifter for me - got it direct from the factory in the states.
I just imported 2 Gene Berg locking shifters one for me and one for a mate. Not fitted it yet but it looks the mutts do dars.
I went for Gene berg because of the locking option but csp are also good. Importing a locking shifter isnt cheap, by the time it got to me after import duties, vat and parcel force also hitting me with a handling fee it cost about £495 a shifter. Exchange rates are not what they used to be either. Gene Berg were realy helpful. If you want a "non" locking Gene Berg shifter try Prowagen they usually hold them in stock. Hope this helps.
sparkywig said:Just bolt the shifter to the floor, no shift plate required.
MrAndyP said:sparkywig said:Just bolt the shifter to the floor, no shift plate required.
Thanks. reason i ask,i already fitted it without,but still get reverse without the lever. i havent changed the rod bushes yet though,so will do that and then try adjusting it a little......
sparkywig said:MrAndyP said:sparkywig said:Just bolt the shifter to the floor, no shift plate required.
You're not alone, it's not the bushes or gearshift, but the shite Scat shifter.
It takes a bit of practice to select 2nd without graunching into reverse instead.
There's a thread on thesamba how to modify the flimsy reverse lockout.
Stevec said:Andy
When I first got my bus back from the mechanic it still crunched into reverse while trying to get 2nd and went into reverse without pulling the lever up, I even questioned it on here and was told that's just the way it is. I wasn't happy and it pissed me off so went back to the mechanic and after a little 5min adjustment it's perfect now.
I saw the same thing on samba that sparkywig mentions about doing a bit of DIY on it to make it work, luckily I didn't need to.
Oh just to add I had new bushes etc installed when he fitted the scat shifter.
Stevec said:Alex are you saying the scat shifter you sold me a few months back won't last me then?? If so I'll exchange it for a csp one please!
