sorry, been at work so couldn't give much info! right, just got back from my late shift and thought of something. the mechanic said he'd tightened my ignition barrel as the key always spins in it slightly, which was probably the right thing to do!!!.however it always has moved a bit but I obviously know the knack of popping the key in without the barrel spinning. so I tried starting it in its new tightened position again and it cut out. angry with it I thought stuff this and span it back into its original loose position, and now she's starting no probs . could the position he'd fixed it in made a wire touch metal, causing it to cut out,and as after cutting out with the key in still the dash lights were flickering as I was wiggling the key?!?!
neighbours must think im daft starting my van numerous times at 11pm at night!!!!
