Can anyone help with my headlight problem.
I have a 1972 crossover which has had halogen conversion fitted by a previous owner.
The problem I have is that the right hand side dipped beam seems to be on in every position of the switch.
Sidelights: both sidelights are on and the right hand dipped beam
Headlights: Both are on but the right hand side is a lot brighter.
Full beam: both are on but low beam stays on also on the right hand side. Left hand is fine with a clear difference in the beam pattern between high and low.
The left hand headlight and side light works fine throughout.
I also seem to have some spare wires, maybe as a result of the conversion.
The connections are as follows.
Right hand side:
Side lights 1 to earth
1 grey
Headlight: Red to Earth
1 Black and yellow
1 Black and white
Spare wires: 1 Brown, Green and yellow to fuse 3, 1 Brown and white, 1 double brown with earth connector.
Left hand side:
1 to double grey
Headlight: Red to earth
1 Yellow
1 White
Spare wires: 1 Double Brown with earth connector, 1 Single Brown,
Any help appreciated.
I just need some pointers as to what I should check.
Right hand side:
1 grey
1 Black and yellow
1 Black and white
Left hand side:
1 to double grey
1 Yellow
1 White
