Help with how to adjust rear spring plates
fozworth
Sep 11, 2013
684
Bristol
Ive got t2d adjustable spring plates on my 69 bay ,but need to turn one spline to get a bit more drop .is this easy with adjustable plates fitted .?
Dead easy! Start the process as for stock, but you'll finish much sooner :)
Silly question - but are you at the limit of your travel on the adjustable ones?
Bear in mind the camber will increase by turning a spline - make sure this won't cause issues when trying to remove the wheels.
Hi yes the reason I want to lower by one spline is that due to my new lowered front end the rear adjustable spring plates at the lowest setting still give the bus quite a rake so I'd prefer to gain some adjustment back by turning a spline ,and hope one will do it .
Cheers ja
