Stirlingmoz
I've just treated myself to a used pair of the metal chrome finish inner door handle trims to replace my black plastic ones.
They came with black plastic inserts.
The problem is they don't seem to fit over the screw which retains the metal portion.(fit perfectly without screw)
I am re-using the screw that held the old plastic trims.
Is there a shallower screw I should be using ?.
Should there be (or should I drill) a hole in the plastic trim and screw through it ?.
A minor problem I know but a tricky sucker :? .
Stirlingmoz
Stirlingmoz
