Bigbear
So I've just had the engine out to replace the crank shaft seal, (done loads of other bits whilst doing this) since doing this my luck has been awful!
1. Whilst refitting the gland nut in the flywheel the poxy thing snapped in two! Leaving me to tap the threaded part out with a screwdriver (stop all work whilst waiting for a new one to be delivered)
2. Took the gearbox out only to find a seal missing (oil pissing out everywhere!) also the sump plug was chewed to bits! (Stop work whilst waiting for delivery!)
3.refitted the long gear rod upside down (prick!)
4.noticed my brake reservoir was dry, poxy leak underneath!(stop work to wait on delivery!)
5.found nasty rust whilst repairing the above!
6.had a member of public point out the bus looked weird from behind(rear bearings, trailing arm bushes, and possibly cv joint buggered!)
7. Looked under the van tonight and oil looks to be leaking from the crank shaft seal still!
I've had enough!!!
I've had enough!!!
