Justin & Muttley
Got myself organised, got a huge reel of welding wire, and got started...
First I had to fabricate a wavy piece of steel for the cargo floor from 1.2mm steel sheet (not easy) - it doesn't look like the tidiest of jobs but it's good and strong - then two smaller patches nearby:
Next I tackled a small hole at the top of the wheel arch where the sink drain used to go through, I had to be careful because it's quite close to some fibreglass sheet that I want to keep intact for the moment:
Next, the trickiest bit - an 'L' shaped piece behind the passenger bulkhead - this was tricky because there is a curved section as it joins the inner wheel arch - I've still got a bit of grinding down to do but it looks OK to me!:
So, just one repair to do in the back - another tricky bit the same as the passenger side, this one's a bit bigger though and may have to be done in two sections to avoid distorting the panels:
Once this is done I can paint the cargo area of the van, then I'll tackle the cab floor next - both footwells need doing (should be fun!)...
Any feedback gratefully received (including any hints on improving my technique), thanks
J&M
J&M
