Managed to spend a bit of time on the bus this weekend
First job was to fit a seatbelt for the little one. Got a bracket from over on the late bay to mount it on to the factory points:
So this meant we could take Penny out for her first drive in the bus
Just a short jaunt tot start with to see how she took to it. She started like this:
and ended like this, so I think it was a succces!:
So we followed that up with a flying visit to Stanford hall, stopped a couple of hours but left by 10:30. Got a nice new sliding door handle from busok.
Before:
After:
On the trip to Stanford hall there was the occasional strong smell of petrol from the heating so that warranted some investigation on Sunday. Sniffing around the engine bay it appeared to be from the right carb, fuel pipes were dry so I whipped the carb off. It looks like the accelerator pump gasket was crimped when it was installed so each pump squirted a little down the side of the carb :eeK: didn't think to inspect them as they were brand new carbs!
I straightened it up and made sure the previously creased bit was at the top and that's solved the problem and got rid of the leak.
Decided tp check the jets and everything whilst the carbs were off and there was a bit of water and some crud in the bowl, probably from the oldish petrol due to using LPG previously. Gave them all a good clean:
Finished the bank holiday by heading out for a picnic
Just booked in to a rolling road on the 18th so I can get these carbs set up properly, can't wait
Before:
After:
