Late Front Discs with red9 wide 5 adaptors
5erge
Mar 28, 2009
961
Just outside London
This is an issue I spotted a while back but left it on my to do list.
Basically with this combination my wheels bolts are hitting the caliper, little bit unsure what to do. Don't really want to grind back the wheel bolts nor do I want to grind any clearance out in the caliper :cry:
It's stupid (but clearly important) ***** like this that delays me.
Des
are the bolts screwing through the adaptor and hitting the caliper? if so why dont you want to shorten the bolts?
If I cut back the wheel bolts I'd have to do in in such a way that there would be no thread exposed the other side once screwed in (hope that makes sense) my worry is from a safety aspect.
If I have to cut then so be it, you can understand my concern though...
Des
any thread sticking throu isn`t doing anything , as long as they are flush with the back of the adaptor you will be fine , although i`m not a lover of adaptors ,just periodically check the bolts are tight
