- Joined
- May 17, 2021
- Messages
- 454
- Reaction score
- 388
What size can I comfortably fit in the back? I have one already but it is backwards and a bitch to remove to read the specs. I killed it last year so was looking to maybe upgrade.
I just installed one in my bus. I got the same size as the other one. I’m putting together a circuit so that when the leisure battery runs down while camping the main battery charges it. The leisure battery doesn’t take anything away from the main one until the engine is running.What size can I comfortably fit in the back? I have one already but it is backwards and a bitch to remove to read the specs. I killed it last year so was looking to maybe upgrade.
Lithium would be nice but it means rewiring the bus and my external hookup which currently charges the lead battery. Also, I have a voltage readout in the camper which is pretty good at monitoring. I have no heavy usage items apart from the stereo to its enough to keep phones charged etc.I upgraded to a lithium Bluetooth 105ah Fogstar drift last year, half the weight of lead acid, slightly smaller, terminals right way round and the app allows you to monitor condition volts, ah, temp, dis/charging rate, no more having to guess will it last the weekend/festival/camping trip………
