sharman
Well, I'm about at my wits end and on verge of meltdown I set off to lower my bus and ended up clenching my buttocks every time a see a bump or pot hole in the road. Originally, She sat on 5.5x15 alloys with 185/65/15 tyres. She was approx 3.5" higher at the front also.
So, after seeing other stances, I fitted dropped spindles/coilovers and adjusters on my beam(thats another story!). The adjusters were set at about std height. This made the front tyres really close to the arch, so I fitted 175/55 15 tyres for more clearance.
This dropped the front even lower, making it nose dive at the front by approx 3.5" and scrape every hump
I had to go on holiday like this, 350 miles of pure un-nerving.
Once back of hol, I wanted to fit adjustable springplates to even things up as I did'nt want to lower rear on skinny tyres. Unfortunately, everyone seemed to be out of stock, so I opted for Horse shoe plates. What could possibly go wrong
Well it did, big time. Horseshoes on and height of the camper was perfect and virtually level, except one tyre had clearance, the other side was rubbing the arch. We had to deflate both tyres and wrestle em in.
Apparently, the offset of my Midland wheel BRM's is shite and I make it ET20. I was advised to fit std steel wheels if poss because they give more arch clearance.
Great, I fit 14" std wheels with 185/14 wheels and yes, the wheel fits and gives more clearance. Unfortunately, the tyre bead had to be broken to allow it to fit and went with a pop when inflated, so that should be fun to get off :roll:
Anyway, she was good to go to Stanford hall camping, except that when loaded with gear, there was knocking/banging at the rear everytime we went over a bump and the front was still scraping. Looking from the rear, it looks level, but has more camber on one side than the other.
Needless to say, I'm not happy and the wife hates it :msn4:
Wish I'd left her alone, but don't know what to do to fix it as I the pockets are virtually empty. I aint got std spindles cos they were p/x'ed, I can't afford new alloys to compensate for offset. I think my first port of call is to remove the horseshoe plates, once I've sawn the damn tyres off to remove the wheels :mrgreen: Oh the joys
