Major Fuel Leak! - Possible 'Firetec' Group Buy
Thanks for posting this pic ,as I also run twins. So looking at this I will have to change mine to Horizontal mounting instead of upright so can we change mine please...
R73 - Rob Kerr - Upright/Roof (To be Confirmed) - Switch Green OK /Red Discharged - Delivery (Woking) To be Confirmed
Frisco 69 - Matt Jewel - Upright - Dual Switch - Delivery Eastleigh
Ozziedog - Steve Walker - Upright - Dual Switch - Delivery Bristol
froggy - Simon Worton - Upright - Dual Switch - Delivery / Collection (depending on time scales)
Toffo24 - Peter Roffey - Horrizontal - Dual Switch - Delivery Folkestone
AGC - Andy Chamberlain - Upright - No switch - Delivery to Soham,Cambs
willevans79 - Will Evans - Upright - single switch (Green OK) - Delivery to Aylesbury
Nice one guys, any news on payment options, ideally I'd like to be able to put it on a credit card (post Xmas skint!!)
Will
willevans79 said:
R73 - Rob Kerr - Horizontal - Dual switch - Delivery Woking
R73 - Rob Kerr - Horizontal - No Switch - Delivery Woking
Will
skin69 - Nigel Greensmith - Horizontal - Switch - Delivery/Collection (To confirm - Peterborough)
andy1564 - Andrew Lockwood - Upright - Single Switch ( Green OK ) to Collect
Rusty Lee-Lee Pickering-Horizontal-Single Switch-Collect from show
Hi all, can anyone clarify the difference between the single switch and the double switch.
I looked on firetec's web page but couldnt see anything.
Otherwise I am ready to order.
Cheers Kyrk72
As Graham mentioned - it would make sense that single acting switch would show one led (ie green) and double acting switch would show red or green. I will try and speak to them today and get confirmation.
Millhouse - Rob Dunn - Horizontal - Dual Switch - Delivery Gloucestershire
Had a great chat with Tim from Firetec today.
Single switch will switch power off on activation. so if you wired it to a green led - this would go out when firetec operates. you could wire this switch to an electric fuel pump for instance.
the double switch will do the same plus switch power on. this could be wired to a buzzer for instance.
when they supplied their system to an earthmoving machine company they found the best solution as to wire the single switch to the radio!
I think there may be room to mount upright on LHS behind carb (if running twin carbs) the extinguisher measurements are 340mm high and 85mm dia. will have a look tomorrow.
Apparently upright is the best way to run these - the roof mounted option has a different pick up tube inside.
froggy - Simon Worton - Upright - SINGLE SWITCH - Delivery / Collection (depending on time scales)
Ok just edited mine to read Single switch, as i can then wire this via a fuel cut off solenoid valve (that i bought as part of a group buy a few years ago) so if the extinguisher goes off i loose the green LED but also cut off the fuel to the engine
skin69 - Nigel Greensmith - Horizontal - Single Switch - Delivery/Collection (To confirm - Peterborough) - 2x Total
I hope this works?
I need 2x the same spec...
Cheers Nige...
Rusty Lee-Lee Pickering-Horizontal-No Switch-Collect from show
Cali_bay - Simon - Upright - single Switch - Delivery or show collection
Kyrk72 - Andrew Taylor - Upright - single switch - delivery or show collection
apologies for my ramblings - just done a search and noticed this has all been covered before :oops:
I may change the spec of my order - but dont spose it matters too much as i guess if we want delivery we'll need to speak to firetec anyway.
Were only a couple away from max discount as well!!
strutt - Luke Hubbard - Horizontal - No switch - Collection from solihull
Luke
hi, can anbody here recommend which system would be best for me?
i'll be running a 2L subaru engine and will have a small bay engine inspection hatch fitted.
spare wheel well will be removed and a leasure battery will be fitted.
cheers paul.
