Went to the garage on sunday with a bit of hangover but still excited to get the back down as i was already buzzing with how the front was looking. We had a quick read of the fitting instructions that came with the springplates, but to me these seemed a little daunting if i'm honest with the mentioning of tying heavy chains to the jack and bus or getting fat mates to sit in the back for the load :shock: .
Again we jacked up the rear end and placed the bus on axle stands. Stripped wheel off and had a good look at how we were going to set about this task. first problem ; the brake lines go through the orginal springplates which do not have cut outs in like the red9's, second problem; no chains and all my fat friends were having there sunday carvery :lol: , third problem; noticed springplate covers were corroded and we didn't have any spares :roll:
So we decided just to crack on and see how it went :? . Placed jack under springplate to take up tension, tried to remove springplate covers but these were stuck solid and bolts were a littlke chewed....luckily Ian has an Irwin set so with a little persuasion he managed to get them off, without that set this would probs have taken hours. slackened bolts behind drums (think there was 4). Now for the fun part, we didn't want the extra has of bleeding brakes so with a little head scratching Ian got his little air grinder out to modify the orginal springplates with a slot like the red9's
TAKE MEASUREMENTS HERE OF DRUM TO CHASIS AND SCORE A LINE ACROSS SPRING PLATE IN AN UNLOADED POSITION FOR REFERENCE WHEN PUTTING NEW ONE ON
Took top strut bolt out and left attatched to the drum and brake lines, removed arm from drum and it should now just swing out of the way. To do this we took the clips off the brake lines to give them plenty of slack !!! Remove bump stops or cut them in half.
raised and lowered the jack whilst giving the springplate a little tickle with a copper ended hammer and out it popped
Now line up the new springplate with the scored line maked up previously in an unloaded position. You may need to jack the springplate up and down to wiggle it into place whilst hammering it in
:shock: :lol:
Put everything back together but leave bolts loose so you can measure everything up before tightening.
Nows the ball ache let all air out of tyres using valve remover. I have later wide arches on mine so it was a little easier to get tyre back on but i still had to roll lip to get them on :x do other side, drop and admire the stance 8) .
The front is set at its highest setting so could still go down a couple more inches :msn4: :msn4:
