MOT day tomorrow, so Sod's law the van throws a wobbly. Just got it out of the garage ready and it struggled to start, and when it eventually got going, it was idling low and very lumpily. Left it to warm up and the idle improved, but still didn't seem like it was firing properly. The engine has always shook a lot and is more noticeable at idle revs. I pulled the leads one by one and have found that both 1 and 3 have no effect on the idle. Both plugs are receiving a spark, albeit they don't look too strong. I need to pull one of the OK ones to compare. Either way, ive swapped the plugs from cylinder to cylinder and nothing changes.
The engine has only done a few thousand miles so I'd expect it to be in good nick. I guess what I'm looking for is some way of knowing what to check / change next. I have adjusted the valves since I last had the van out, but can't remember what it was like before - I say that because it seems to drive ok now, although can only do a limited run up my road because of lack of mot. The valves didn't need much tweaking which makes me think I haven't cocked this up. The compression tester I have unfortunately doesn't come with the right adapters. So, what next?!
