MOT... steering rubbers?
Slammed
Jun 13, 2008
2,325
Does anyone know if my bus will fail the MOT with damaged and split balljoint and drag arm boots?
If so, any idea who sells new drag arm boots?
Ta
Mine was an advisory (on my bug).
Depends on your MOT man I suppose, this has been asked before on VZi and some people have been failed for it iirc.
Ball joints Item 20
http://www.vwheritage.com/vwh/VW-Camper-Van-Parts%5CBus-Parts-1968-79%5CSteering-Suspension%5CFront-Suspension%5C?templateID=vwh" onclick="window.open(this.href);return false;
Track rod/ drag link item 37
http://www.vwheritage.com/vwh/VW-Camper-Van-Parts%5CBus-Parts-1968-79%5CSteering-Suspension%5CSteering%5C?templateID=vwh" onclick="window.open(this.href);return false;
Thanks Clarkson, I somehow missed the dust caps when I looked earlier! 8)
Alternatively would they pass if they were gaffa taped up?
And will CV joints with grease leakage fail as well?
if you gaffer tape it Mr MOT man will definitely pull it off to see what nasties are hiding for sure, not sure about the CV oil leak. i would think this would be at least an advisory.
Changing ball joints boots is fiddly but easy enough to do, cv boots are a bit harder possibly needing a special tool?
A Geordie guy I worked with a few years ago said that when he had to replace rubber boots/gaiters that he cut the old ones off, bought new ones and cut them , both with a Stanly blade .Then instead of having to undo everything to get them on just glued them back together again using cycle puncture glue. Never tied it myself but in theory it should work and save a lot of hard work.
In the other hand, we had new ball joints pressed in complete with new rubbers, fitted everything and let it back onto its wheels and watched the new rubbers split, without turning a wheel :?
I had this problem too, only replaced the balljoint rubbers a couple of months ago.
Anyone know if there's a right way to fit them?
