uber cool
My gearing is much better since I fitted these, 4th is like 3rd. Must admit need more power now :lol: as having to change down on inclines (more so than usual)
A very good point! Hence the £80 tig welded balanced fans at all good stockists of such things.sparkywig said:You need to be careful with increasing the fan speed, unless it's a welded and balanced fan as the stock ones come apart at sustained high revs.....
ZedBed said:A very good point! Hence the £80 tig welded balanced fans at all good stockists of such things.sparkywig said:You need to be careful with increasing the fan speed, unless it's a welded and balanced fan as the stock ones come apart at sustained high revs.....
...and it won't cool the oil enough anyway so remote cooler, or adjust tin to fit a T4 cooler.
When will it all end? :lol: All I want is to potter about in a lowered bus with a big engine and just now and again hack along without it going bang!
Is that on the speedo, or adjusted? Either way, your engine will last forever and love you very much.sparkywig said:But I still drive at 50-55mph.![]()
67panel said:thats the prob mod one thing and it leads to modding everything else,or keep it stock :msn4:
I dont do stock![]()
Knife edge descision for me - I love my stock single porter, but the money was burning a hole in my pocket and I wanted something to show for it before it disappeared into the abyss of everyday mundanity...sparkywig said:ZedBed said:A very good point! Hence the £80 tig welded balanced fans at all good stockists of such things.sparkywig said:You need to be careful with increasing the fan speed, unless it's a welded and balanced fan as the stock ones come apart at sustained high revs.....
Stick to stock then......
Me neither - I like messing with it and it didn't need much bodywork...sparkywig said:67panel said:thats the prob mod one thing and it leads to modding everything else,or keep it stock :msn4:
Nor me, mainly due to the fact that there wasn't much original left on my bus.....
:lol: Bad boy! I knew you'd be up to something... Single carb? I wonder if it would like a single carb - you'd loose some HP, but it would look so stock, and as we know a lot of peeps think SP's must be crap which would just add to the satisfaction. Laurie put me off when I suggested it, I think he's happier doing what to him is a stock build, so he knows he can get the carb jetting right first time etc etc. I was going to push him to do it, then I found those TP heads and that swayed me. Single carb was sillyness to far for him to get involved in - he has to make a living.sparkywig said:I'm playing with the idea of a 2056 single port as almost all the parts are in the garage, except the heads need flycutting....
....but I do like the 1600 single port.
Great idea! There is no Zero mph on mine anyway, the guage starts at 10mph and that's where the needle rests. :lol: Wierd these earlies.Nugsy said:Not sure its the answer to the speedo question when fitting smaller tyres but i recently broke my speedo after fiting a new cable. Had a spare clock lying round so drove it with all the clocks out first. then put just the speedo in. Thats when it hit me, set the GPS up on my phone and drove down a mile long road reading gps speed. Took the needle of and set it back a bit more. kept doing it till at 30 the speedo and gps read the same (only real speed camera issue i'll hit as if i get 60 i'll be proud) seems to be doing the job all back in working and reading correct speed now.
Mark6455 said:So what should I be looking at then dude
Tyre size on rear?
