I fitted a new tank sender when my motor was out and have found that the needle on the dash display flicks back and forwards and sometime when you initially turn the ignition on it doesn't move until you start the engine .would it be a faulty gauge??
I did the check where you turn the ignition on and ground the wire from the gauge in the engine bay and the needle When across to full ,so no worries with power. Any ideas or remedies
