I realize how old this thread is... you might not even own this beauty anymore
However, if you do, and could give me a little info on it, i'd really appreciate it.
I'm looking to do mine pretty much identical, as far as wheels and stance goes ('70 westy)
Do you remember what setup you used to get the 130 bolt pattern in the rear (assuming it's a '70 or earlier and had a wide 5 drum)?
If you could share the air shock setup, would be great as well. I'm mostly wondering if the shocks work as a dampener when deflated, and you can just pump some air in them when needed, OR if they must have a minimum amount of PSI at all times?
Also, if anyone else might know the answers to the above Qs, I'd appreciate your input.
Many thanks in advance
