Nelly said:The cafe?????
Nelly.is the rad ducting working well? I'm fighting a battle with the porsche motor, so might go water cooled! from what I can see you have the ducting blowing over the rad and down then out, is that correct?Nelly said:This is where the rad will live, ducted from the front and when i've made the belly plate it will seal the rad in so any air will be forced through the rad.
must admit I have been looking re cooling on the vwkd, but think most seem to have the air flow the other way round, then struggle to dissipate the heat, your method seem to make more sense!Nelly said:Uber the rad works great especialy as i'm running a tubo motor, but it is boxed in more than in this pic and yes this is the best way to flow the air through the rad so the hot air gets forced out into the moving air under the bus. Check out vwkd for more info on cooling
Very tempted I have the engine, but it just looks ***** next to the Porsche engine. The Porsche engine looks fast not moving and sounds ace. 8) even with a knocking big end :lol:andewilson said:go for it uber take a step over to the dark side. i nearly went down the alfa route but settled for diesel instead for economy.
