So i havent done alot to my bus recently because iv been trying to sort the front of my bug out the old beam was rotted at the bottom of the front towers so i made a new 6" beam and kept the shocks, still got to adjust and tighten etc etc but here u go
Bit of progress, fitted gearbox, starter, shafts etc ordered a few things like clutch earth strap and battery connections,
Got stuck into removing the floor,
Got a few more cutting discs ready for sat, need to order floors now,
Just a quick one to the left of the gearbox in the picture theres a gromit with wires coming through some are wired up but theres a single one left, whats it for?
I think im going to have to drop the rear a little, looking at driveshaft angle even with engine in i dont think the shafts will be at much of a better angle :/
Also fitted a new hand brake pull and lever but the actual chassis part that the bit levers on through the floor was cut out :/ anyone got a pic so i can make a new one? Cheers
Iv been fiddling with the wiring but i havnt got a few of wires correct iv have no dash lights or indicators and when i turn headlights on the fuel guage jumps to full :/??
But it does turn over
Wont start as no fuel plugs or leads at the time
Gotta paint pulleys now
Fuel gauge jumps to full!
Just wired my tacho from Aspro and when replacing saw the one wire to the fuel gauge was loose
and earthing out on the side of the gauge. When I tested it with the ignition switched on it did as you describe.
Recentered this and glued it , problem solved.
