Pete B
- Joined
- May 3, 2008
- Messages
- 2,001
- Reaction score
- 3
- Year of Your Van(s)
- 1968
- Van Type
- Bus
Not me thankfully, but a good friend with a '76 bus has just encountered gearbox problems. Basically all is fine apart from 2nd gear which apparently will not engage, makes lots of grinding noises and jumps out when trying to select. All other gears are fine so I dont suspect problems with the external shift mechanism, it must be internal to my way of thinking. Anyone else encountered or heard of this being a 'known' problem? Obviously the 'box needs to come out, but with exchange boxes being around the £700 mark, can anyone recomend a good gearbox man (cogbox I know of obviously) preferably around the Peterborough area, to repair said 'box?
Any help, suggestions, advice or opinions gratefully recieved. Also Mike asked if I would do the 'box swap, not a lot of spare time so anyone up for it or recomend someone local? Tim is always busy and another local guy is just too wierd and not trustworthy....
Thanks.
Thanks.
