My oil pressure warning light has stopped working...
It last came on when the oil level was low, not sure how it was so low as I had been regularly checking it but during that 300 mile interval the engine had got to 120* on my temp guage 3 times so I guess the thinner oil when hot found was to escape. Anyway completely changed the oil and the pressure light has not come on since either with the engine running or not. I removed the dash guage fuse and the bulb illuminated so I guess the problem is not there, the wiring diagram shows the wire goes straight to the switch and therefore this must be the problem?!?
Is there a test I can do to ascertain that it is the switch before I buy a new one?
Do they just screw in and out? ie. can I replace it with everything insitu?
