Woohoo Roadtrip!
Just booked us a few nights into Bude Holiday Resort at the start of next month.
arty0049:
Pics to follow, hopefully full of happy smiling faces, not grumpy/bored, and with oil stained hands...
It'll be a big test for Old Nell.
The furthest we've been so far is to Skeggy and back, about 175 miles total. Give here her dues, she ran beautifully albeit it was freezing with the draughts.
So, job list for when I get back from work on the 1st June - no pressure:
Oil Change - Really should have done this before now. I rebuilt the engine last year with new barrels, pistons, bearings, oil cooler, etc and I must have racked up a couple of hundred miles since then, so need to drop and put in fresh oil.
Draught Excluder - I've got some old door seal from the original trim that we ripped out on the dismantle a few years ago which I reckon I can probably glue to the bottom of the arch inside the door where there's a massive gap. Gonna check around the front vents too to make sure all is as it should be and maybe adjust the vent rods.
Curtain Rail - On the back left window there is the curtain strip that needs a couple of screws in which will also hold the roof lining down so double whammy there... :roll:
Interior lighting - I noticed on our last overnight trip that our lighting had stopped working so I could do with sorting that out. Not too important as we have external lighting for in the awning.
Tyre pressures - Nell will have been stood for a month or so by the time I get home, so tyre pressures will be checked. What pressures everybody putting in their tyres at the moment? My tyres are 185R 15 I think.
There's a sharp edge to the new trim on the sink unit which needs filing down to make it safe.
New window winder mechanism to drivers door - I'm not sure if its down to the mechanisms I've bought or the seals that have been retro fitted to the door, but this'll be the 4th mechanism that Nell has had. She had the original which was knackered when we bought her, A GSF unit that was dog toffee, then a unit from JK which was better but still clicked at the top and didn't completely shut the window. Fortunately, when I bought the last one from JK, I bought 2 instead of 1 by mistake, so I'll swap them out... again :roll:
I think that's about it.
It'll just be a case of topping up the water tank, loading the van up with beer, food, beer the misses, the daughter and her two mates... :shock: some beer and then heading off.
Roll on the morning of the second of June.
Give us a wave if you see us and wish me luck!
