Petrol sender unit
Dub d
Jan 27, 2015
19
Norwich
Hi fellas,
Took me bus out last nite for its first drive after it's resto :D all seems pretty fine apart from the petrol gauge was not working! :( I've replaced the the sender unit with a new one so it can't be that just wonderd if anyone had any ideas as what it could be?
Darren
Check the connections behind the dash - otherwise its engine out, firewall out, fuel tank out to get at the sender!
Unless you cut an access hatch! :msn4:
earth the wire that comes through the bulkhead to the sender, gauge should read full. will tell u if the problems with wiring or sender unit :)
