I am doing a top end rebuild and was wondering about the tolerances for piston weights.
I have a set of Mahle cast pistons including pins & rings with 3 that weigh 504 grams and one that weighs 498 grams.
Is the difference between them acceptable or should I machine the other 3 down to the weight of the lightest piston?
I know that ideally in order to balance an engine you should include the weight of the entire reciprocating mass, which means the con rods as well but I don't want to split my case.
Any thoughts ?
Any thoughts ?
