I seem to have a problem with either my coil or the Dizzy. Basically I've only driven my 69 panel from Kent to Bristol when I bought her and she seemed to drive pretty well.Ive spent th last few months restoring her and whilst tidying the engine up I fitted a MSD blaster 2 coil .I also fitted new points condenser ,cap etc. The motor seems to run fine for a bit then I loose the spark at the points as the close up and are heavily burnt /pitted. I thought it might be my dizzy as I found that the vacum advance diaphragm body had got bent n damaged .my mate leant me a 009 (just to get me running ) which I fitted new points to and it started but has done the same and burnt the points n condenser out. Electrics seem OK motors not live or anything .Could it be the MSD blaster coil is to much for the stock setup?
