StefansBus
- Joined
- Nov 20, 2015
- Messages
- 84
- Reaction score
- 0
Hi all,
A friend and I have just installed a rack and pinion steering in my early bay. Some pics of the prototype "kit" and installation here: https://forum.bulli.org/forum/viewtopic.php?f=7&t=25532
It's a Opel/Vauxhaul early Astra/Cavalier rack and a T25 relay box plus a bunch of stuff designed by my friend. You'll see all the parts in my link.
Some metal work in the master cylinder mounting area was required as well as slight clearancing at the front beam between the tubes on the left side.
The steering is now very light due to changed gearing ratio (so it takes more turns form stop to stop) and is virtually without any free play.
I have noticed a decreased tendency to return the wheel to neutral out of a corner. I strongly suspect this is due to the motion of the tie rods which is now completely linear and was previously slightly "circular" due to the steering arm (idler arm?) at the centre steering bolt in the axle. This arm is now no longer needed so the inner and outer wheels turn at exactly the same rate, which is not quite the case with the original steering geometry.
I would welcome some feedback from others who have converted to rack and pinion as to whether or not the same has been observed.
Stefan
Stefan
