Rear bump stop
rustydiver
Oct 24, 2006
1,226
somerset
Want to lower the rear 1 outer spine 2 at the most (want to get it in the garage), looking at it today the rear bump stop is about 1cm from the dish thing it bumps on, if i lower it it will be touching or a lot closer, so can i cut some of the bump stop was thinking 1 bump out of the 3.
yeah cut the first bit off fella otherwise you'll have a very bouncy ride where its sat on the bumpstops all the time.
that's what I did with mine, just cut one if the bumps off with a hacksaw. Lowered 1 spline. Dropt the bus about 1 1/2" at the rear
as going to go down 1 at first, if i go two will it be about 3" then. Dont want to go to mad as there is no interior in it at the moment.
When i measured it was only about 1" i needed to loose but it would be a tight scrape to get through.
Suppose i could put a few bags of sand in the back when putting in the garage to lower it a bit more. :msn4:
