rolandtheclipper
- Joined
- Aug 9, 2010
- Messages
- 172
- Reaction score
- 0
Help my van was lowered before i had it and no indication to how the rear is lowered. just it is sitting on the bumpstops most of the time. there is 4" from the bottom of the shock to the plastic bit on the outside of the shock, you can lift the back of the van you can get the shock to go up about 4" and the wheel still does not lift..... you can get the wheel off if you keep jacking.
The ride is not the best. how long should a standard gas strut be? so i can raise it a bit or sort it. i say raise it exhursh hits the ground on speed bumps. not sure if the torrsion bar has been adjusted.
