rear lights gone mad
Wannabay
Mar 6, 2007
517
205
London
This is what my rear lights do
side lights/main beam on - offside rear light OK; n/s rear light on but dim
ditto - press brake pedal - o/s brake light Ok; n/s light goes out completely
but both n/s and o/s brake lights work fine if side/main beam off
I have cleaned contacts and tried a new bulb in n/s rear but get same result
any ideas?
Check the earth connection of the lamp assembly to the body, both sides. Which type do you have as you don't give a year?
Common problem with that type of lamp assy. Originally they relied on a little spike puncturing the paint film to make the earth. In later versions VW fitted an earth tag on the back of the lamp house with gave a more reliable earth.
